Create a share-level ACL on a CIFS share
Creates a share-level ACL on a CIFS share to define access rights for a specific user or group. This allows you to manage permissions and control access to resources within the share.
HTTP method and endpoint
POST /protocols/cifs/shares/{svm.uuid}/{share}/acls
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the share acl. -
share- Existing CIFS share in which to create the share acl. -
user_or_group- Existing user or group name for which the acl is added on the CIFS share. -
permission- Access rights that a user or group has on the defined CIFS share.
Default property values
type- windows
Related ONTAP commands
vserver cifs share access-control create
share |
string |
path |
True |
CIFS Share Name |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
share |
string |
CIFS share name |
svm |
type |
string |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
user_or_group |
string |
Specifies the user or group name to add to the access control list of a CIFS share. |
Example request
"permission": "string",
"share": "string",
"svm": {
"name": "svm1",
"type": "string",
"user_or_group": "ENGDOMAIN\\ad_user"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655470 |
Failed to create share ACL because the share does not exist |
655446 |
Failed to create share ACL because the specified Windows user/group does not exist |
4849678 |
Failed to create share ACL because the specified UNIX user/group does not exist |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
The permissions that users and groups have on a CIFS share.
permission |
string |
share |
string |
CIFS share name |
svm |
type |
string |
user_or_group |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
