Add NVMe subsystem hosts
Adds NVMe subsystem hosts to an NVMe subsystem, allowing the subsystem to recognize and interact with the specified hosts.
HTTP method and endpoint
POST /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Adds NVMe subsystem host(s) to an NVMe subsystem.
Required properties
nqnorrecords.nqn- NVMe host(s) NQN(s) to add to the NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem host add
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the |
records |
array[records] |
An array of NVMe hosts specified to add multiple NVMe hosts to an NVMe subsystem in a single API call. Valid in POST only. |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
Example request
"io_queue": {
"count": 4,
"depth": 32
"nqn": "nqn.1992-01.example.com:string",
"records": [
"io_queue": {
"count": 4,
"depth": 32
"subsystem": {
"subsystem": {
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[nvme_subsystem_host] |
"records": [
"io_queue": {
"count": 4,
"depth": 32
"records": [
"io_queue": {
"count": 4,
"depth": 32
"subsystem": {
"subsystem": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72089705 |
The NVMe subsystem host already exists for the NVMe subsystem. |
72089771 |
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089772 |
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089773 |
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string. |
72090001 |
The NVMe subsystem does not exist. |
72090002 |
The POST request of hosts to an NVMe subsystem can only contain an 'nqn' property or 'records' property, but not both. |
72090003 |
The elements in the records array for a POST of hosts to an NVMe subsystem must contain only the nqn property. |
href |
string |
_links
io_queue
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
uuid |
string |
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
io_queue |
nqn |
string |
subsystem |
nvme_subsystem_host
io_queue |
nqn |
string |
records |
array[records] |
subsystem |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
