REST API reference
Add NVMe subsystem hosts
Adds NVMe subsystem hosts to an NVMe subsystem. This operation integrates specified NVMe hosts into the subsystem configuration.
HTTP method and endpoint
POST /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Adds NVMe subsystem host(s) to an NVMe subsystem.
Required properties
  • nqn or records.nqn - NVMe host(s) NQN(s) to add to the NVMe subsystem.
  • vserver nvme subsystem host add
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
dh_hmac_chap
dh_hmac_chap
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol.
io_queue
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the records property is used.
records
array[records]
An array of NVMe hosts specified to add multiple NVMe hosts to an NVMe subsystem in a single API call. Valid in POST only.
subsystem
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
Example request
  "dh_hmac_chap": {
    "controller_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
    "group_size": "string",
    "hash_function": "string",
    "host_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
    "mode": "bidirectional"
  "io_queue": {
    "count": 4,
    "depth": 32
  "nqn": "nqn.1992-01.example.com:string",
  "records": [
      "dh_hmac_chap": {
      "io_queue": {
        "count": 4,
        "depth": 32
      "subsystem": {
        "name": "subsystem1",
  "subsystem": {
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[nvme_subsystem_host]
  "num_records": 1,
  "records": [
      "dh_hmac_chap": {
      "io_queue": {
        "count": 4,
        "depth": 32
      "records": [
          "dh_hmac_chap": {
          "io_queue": {
            "count": 4,
            "depth": 32
          "subsystem": {
      "subsystem": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262186
The "records" array and other host properties are mutually exclusive.
72089705
The NVMe subsystem host already exists for the NVMe subsystem.
72089771
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string.
72089772
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string.
72089773
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string.
72090001
The NVMe subsystem does not exist.
72090003
A host to be added to an NVMe subsystem is missing the "nqn" property.
72090041
An element in the "records" array contains an invalid property.
72090042
The dh_hmac_chap.host_secret_key property is required when setting any other NVMe in-band authentication properties for a host.
string
dh_hmac_chap
string
The controller secret for NVMe in-band authentication. The value of this property is used by the NVMe host to authenticate the NVMe controller while establishing a connection. If unset, the controller is not authenticated. When supplied, the property host_secret_key must also be supplied. Optional in POST.
This property is write-only. The mode property can be used to identify if a controller secret has been set for the host, but the controller secret value cannot be read. To change the value, the host must be deleted from the subsystem and re-added.
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
host_secret_key
string
The host secret for NVMe in-band authentication. The value of this property is used by the NVMe controller to authenticate the NVMe host while establishing a connection. If unset, no authentication is performed by the host or controller. This property must be supplied if any other NVMe in-band authentication properties are supplied. Optional in POST.
This property is write-only. The mode property can be used to identify if a host secret has been set for the host, but the host secret value cannot be read. To change the value, the host must be deleted from the subsystem and re-added.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
io_queue
count
integer
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem.
depth
integer
The I/O queue depth. The default value is inherited from the owning NVMe subsystem.
subsystem
name
string
The name of the NVMe subsystem.
uuid
string
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
dh_hmac_chap
dh_hmac_chap
io_queue
io_queue
nqn
string
subsystem
subsystem
nvme_subsystem_host
dh_hmac_chap
dh_hmac_chap
io_queue
io_queue
nqn
string
records
array[records]
subsystem
subsystem
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
