Add NVMe subsystem hosts
Adds NVMe subsystem hosts to an NVMe subsystem, specifying the hosts’ NQNs to integrate them effectively.
HTTP method and endpoint
POST /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Adds NVMe subsystem host(s) to an NVMe subsystem.
Required properties
nqnorrecords.nqn- NVMe host(s) NQN(s) to add to the NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem host add
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
dh_hmac_chap |
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol. |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the |
priority |
string |
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used. |
records |
array[records] |
An array of NVMe hosts specified to add multiple NVMe hosts to an NVMe subsystem in a single API call. Valid in POST only. |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
Example request
"dh_hmac_chap": {
"controller_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
"group_size": "string",
"hash_function": "string",
"host_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
"mode": "bidirectional"
"io_queue": {
"count": 4,
"depth": 32
"nqn": "nqn.1992-01.example.com:string",
"priority": "string",
"records": [
"dh_hmac_chap": {
"io_queue": {
"count": 4,
"depth": 32
"subsystem": {
"name": "subsystem1",
"subsystem": {
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[nvme_subsystem_host] |
"num_records": 1,
"records": [
"dh_hmac_chap": {
"io_queue": {
"count": 4,
"depth": 32
"records": [
"dh_hmac_chap": {
"io_queue": {
"count": 4,
"depth": 32
"subsystem": {
"subsystem": {
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262186 |
The "records" array and other host properties are mutually exclusive. |
72089705 |
The NVMe subsystem host already exists for the NVMe subsystem. |
72089771 |
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089772 |
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089773 |
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string. |
72090001 |
The NVMe subsystem does not exist. |
72090003 |
A host to be added to an NVMe subsystem is missing the "nqn" property. |
72090041 |
An element in the "records" array contains an invalid property. |
72090042 |
The |
href |
string |
_links
dh_hmac_chap
controller_secret_key |
string |
The controller secret for NVMe in-band authentication. The value of this property is used by the NVMe host to authenticate the NVMe controller while establishing a connection. If unset, the controller is not authenticated. When supplied, the property This property is write-only. The |
group_size |
string |
The Diffie-Hellman group size for NVMe in-band authentication. When property |
hash_function |
string |
The hash function for NVMe in-band authentication. When property |
host_secret_key |
string |
The host secret for NVMe in-band authentication. The value of this property is used by the NVMe controller to authenticate the NVMe host while establishing a connection. If unset, no authentication is performed by the host or controller. This property must be supplied if any other NVMe in-band authentication properties are supplied. Optional in POST. This property is write-only. The |
mode |
string |
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
io_queue
count |
integer |
The number of I/O queue pairs. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue count is being used. Valid in GET only. |
depth |
integer |
The I/O queue depth. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue depth is being used. Valid in GET only. |
io_queue
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
dh_hmac_chap |
io_queue |
nqn |
string |
subsystem |
nvme_subsystem_host
dh_hmac_chap |
io_queue |
nqn |
string |
priority |
string |
records |
array[records] |
subsystem |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
