Add NVMe subsystem hosts
Adds NVMe subsystem hosts to an NVMe subsystem, specifying the necessary NVMe host NQNs. Use this endpoint to manage the NVMe subsystem's host configuration effectively.
HTTP method and endpoint
POST /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Adds NVMe subsystem host(s) to an NVMe subsystem.
Required properties
nqnorrecords.nqn- NVMe host(s) NQN(s) to add to the NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem host add
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the |
records |
array[records] |
An array of NVMe hosts specified to add multiple NVMe hosts to an NVMe subsystem in a single API call. Valid in POST only. |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
Example request
"io_queue": {
"count": 4,
"depth": 32
"nqn": "nqn.1992-01.example.com:string",
"records": [
"io_queue": {
"count": 4,
"depth": 32
"subsystem": {
"subsystem": {
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[nvme_subsystem_host] |
"num_records": 1,
"records": [
"io_queue": {
"count": 4,
"depth": 32
"records": [
"io_queue": {
"count": 4,
"depth": 32
"subsystem": {
"subsystem": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72089705 |
The NVMe subsystem host already exists for the NVMe subsystem. |
72089771 |
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089772 |
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089773 |
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string. |
72090001 |
The NVMe subsystem does not exist. |
72090002 |
The POST request of hosts to an NVMe subsystem can only contain an 'nqn' property or 'records' property, but not both. |
72090003 |
The elements in the records array for a POST of hosts to an NVMe subsystem must contain only the nqn property. |
href |
string |
_links
io_queue
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
uuid |
string |
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
io_queue |
nqn |
string |
subsystem |
nvme_subsystem_host
io_queue |
nqn |
string |
records |
array[records] |
subsystem |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
