REST API reference
Add NVMe subsystem hosts
Adds NVMe subsystem hosts to an existing NVMe subsystem. This operation is useful when expanding host connectivity to the subsystem.
HTTP method and endpoint
POST /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Adds NVMe subsystem host(s) to an NVMe subsystem.
Required properties
  • nqn or records.nqn - NVMe host(s) NQN(s) to add to the NVMe subsystem.
  • vserver nvme subsystem host add
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
io_queue
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the records property is used.
records
array[records]
An array of NVMe hosts specified to add multiple NVMe hosts to an NVMe subsystem in a single API call. Valid in POST only.
subsystem
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
Example request
  "io_queue": {
    "count": "4",
    "depth": "32"
  "nqn": "nqn.1992-01.example.com:string",
  "records": [
      "io_queue": {
        "count": "4",
        "depth": "32"
      "subsystem": {
  "subsystem": {
Status: 201, Created
num_records
integer
Number of records.
records
array[nvme_subsystem_host]
  "records": [
      "io_queue": {
        "count": "4",
        "depth": "32"
      "records": [
          "io_queue": {
            "count": "4",
            "depth": "32"
          "subsystem": {
      "subsystem": {
Status: Default
ONTAP Error Response Codes
Error Code Description
72089705
The NVMe subsystem host already exists for the NVMe subsystem.
72089771
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string.
72089772
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string.
72089773
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string.
72090001
The NVMe subsystem does not exist.
72090002
The POST request of hosts to an NVMe subsystem can only contain an 'nqn' property or 'records' property, but not both.
72090003
The elements in the records array for a POST of hosts to an NVMe subsystem must contain only the nqn property.
string
io_queue
count
integer
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem.
depth
integer
The I/O queue depth. The default value is inherited from the owning NVMe subsystem.
subsystem
uuid
string
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
io_queue
io_queue
nqn
string
subsystem
subsystem
nvme_subsystem_host
io_queue
io_queue
nqn
string
records
array[records]
subsystem
subsystem
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
