REST API reference
Create the Google Cloud KMS configuration for an SVM
Configures the Google Cloud KMS for a specified SVM, ensuring secure key management for your storage environment. This setup is essential when integrating Google Cloud's encryption services with your storage resources.
HTTP method and endpoint
POST /security/gcp-kms
Introduced in
ONTAP 9.9
Usage notes
Configures the Google Cloud KMS configuration for the specified SVM.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create a Google Cloud KMS.
  • project_id - Google Cloud project (application) ID of the deployed Google Cloud application with appropriate access to the Google Cloud KMS.
  • key_ring_name - Google Cloud KMS key ring name of the deployed Google Cloud application with appropriate access to the specified Google Cloud KMS.
  • key_ring_location - Google Cloud KMS key ring location.
  • key_name- Key Identifier of the Google Cloud KMS key encryption key.
  • application_credentials - Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder.
Optional properties
  • proxy_type` - Type of proxy (http/https) if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • security key-manager external gcp enable
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
string
ekmip_reachability
array[ekmip_reachability]
key_name
string
Key Identifier of Google Cloud KMS key encryption key.
key_ring_location
string
key_ring_name
string
Google Cloud KMS key ring name of the deployed Google Cloud application.
project_id
string
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS.
proxy_host
string
Proxy host name.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
svm
svm
uuid
string
A unique identifier for the Google Cloud KMS.
Example request
  "application_credentials": "{ type: service_account, project_id: project-id, private_key_id: key-id, private_key: -----BEGIN PRIVATE KEY-----\nprivate-key\n-----END PRIVATE KEY-----\n, client_email: service-account-email, client_id: client-id, auth_uri: https://accounts.google.com/o/oauth2/auth, token_uri: https://accounts.google.com/o/oauth2/token, auth_provider_x509_cert_url: https://www.googleapis.com/oauth2/v1/certs, client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/service-account-email }",
  "ekmip_reachability": [
      "code": 346758,
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "key_name": "cryptokey1",
  "key_ring_location": "global",
  "key_ring_name": "gcpapp1-keyring",
  "project_id": "gcpapp1",
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[gcp_kms]
  "records": [
          "code": 346758,
          "node": {
            "name": "node1",
      "proxy_port": 1234,
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
65537703
The Google Cloud Key Management Service is not supported for the admin Vserver.
65537704
The Google Cloud Key Management Service is not supported in MetroCluster configurations.
65537706
Internal error. Failed to the encrypt the application credentials.
65537713
Internal Error. Failed to store the application credentials.
65537719
Failed to enable the Google Cloud Key Management Service for SVM because invalid application credentials were provided.
65537720
Failed to configure Google Cloud Key Management Service for SVM because a key manager has already been configured for this SVM. Use the REST API GET method \"/api/security/key-managers\" to view all of the configured key managers.
string
node
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
integer
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
google_reachability
Indicates whether or not the Google Cloud KMS service is reachable from all nodes in the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
integer
Code corresponding to the error message. Returns a 0 if Google Cloud KMS service is reachable from all nodes in the cluster.
message
string
Set to the error message when 'reachable' is false.
reachable
boolean
Set to true if the Google Cloud KMS service is reachable from all nodes of the cluster.
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_state
boolean
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster.
code
integer
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
name
string
The name of the SVM.
uuid
string
gcp_kms
string
ekmip_reachability
key_name
string
key_ring_location
string
key_ring_name
string
project_id
string
proxy_host
string
Proxy host name.
proxy_password
string
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
