Create Google Cloud KMS configuration for an SVM
Configures the Google Cloud KMS for a specified SVM, integrating it with the necessary Google Cloud resources. Use this endpoint to set up the encryption key management system for your storage virtual machine within Google Cloud environments.
HTTP method and endpoint
POST /security/gcp-kms
Introduced in
ONTAP 9.9
Usage notes
Configures the Google Cloud KMS configuration for the specified SVM. Note: This method is only available to the NetApp Cloud Volume Services for GCP.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create a Google Cloud KMS. -
project_id- Google Cloud project (application) ID of the deployed Google Cloud application with appropriate access to the Google Cloud KMS. -
key_ring_name- Google Cloud KMS key ring name of the deployed Google Cloud application with appropriate access to the specified Google Cloud KMS. -
key_ring_location- Google Cloud KMS key ring location. -
key_name- Key Identifier of the Google Cloud KMS key encryption key. -
application_credentials- Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder.
Optional properties
proxy_type`- Type of proxy (http/https) if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used.
Related ONTAP commands
security key-manager external gcp enable
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
application_credentials |
string |
Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder. |
ekmip_reachability |
array[ekmip_reachability] |
key_name |
string |
Key Identifier of Google Cloud KMS key encryption key. |
key_ring_location |
string |
Google Cloud KMS key ring location. |
key_ring_name |
string |
Google Cloud KMS key ring name of the deployed Google Cloud application. |
project_id |
string |
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS. |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
svm |
uuid |
string |
A unique identifier for the Google Cloud KMS. |
Example request
"application_credentials": "{ type: service_account, project_id: project-id, private_key_id: key-id, private_key: -----BEGIN PRIVATE KEY-----\nprivate-key\n-----END PRIVATE KEY-----\n, client_email: service-account-email, client_id: client-id, auth_uri: https://accounts.google.com/o/oauth2/auth, token_uri: https://accounts.google.com/o/oauth2/token, auth_provider_x509_cert_url: https://www.googleapis.com/oauth2/v1/certs, client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/service-account-email }",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"key_name": "cryptokey1",
"key_ring_location": "global",
"key_ring_name": "gcpapp1-keyring",
"project_id": "gcpapp1",
"proxy_host": "proxy.eng.com",
"proxy_password": "proxypassword",
"proxy_port": "1234",
"proxy_type": "http",
"proxy_username": "proxyuser",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[gcp_kms] |
"records": [
"code": "346758",
"node": {
"name": "node1",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537703 |
The Google Cloud Key Management Service is not supported for the admin Vserver. |
65537704 |
The Google Cloud Key Management Service is not supported in MetroCluster configurations. |
65537706 |
Internal error. Failed to the encrypt the application credentials. |
65537713 |
Internal Error. Failed to store the application credentials. |
65537719 |
Failed to enable the Google Cloud Key Management Service for SVM |
65537720 |
Failed to configure Google Cloud Key Management Service for SVM |
href |
string |
_links
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
integer |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
google_reachability
Indicates whether or not the Google Cloud KMS service is reachable from all nodes in the cluster.
code |
integer |
Code corresponding to the error message. Returns a 0 if Google Cloud KMS service is reachable from all nodes in the cluster. |
message |
string |
Set to the error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Google Cloud KMS service is reachable from all nodes of the cluster. |
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster.
cluster_state |
boolean |
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster. |
code |
integer |
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
gcp_kms
string |
key_name |
string |
key_ring_location |
string |
key_ring_name |
string |
project_id |
string |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
proxy_port |
integer |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
