Create a Google Cloud KMS configuration for an SVM
Configures a Google Cloud KMS configuration for an SVM to integrate cloud-based encryption services within your storage environment. This setup is typically used to manage encryption keys securely and automate key rotation processes for enhanced data protection.
HTTP method and endpoint
POST /security/gcp-kms
Introduced in
ONTAP 9.9
Usage notes
Configures the Google Cloud KMS configuration for the specified SVM.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create a Google Cloud KMS. -
project_id- Google Cloud project (application) ID of the deployed Google Cloud application with appropriate access to the Google Cloud KMS. -
key_ring_name- Google Cloud KMS key ring name of the deployed Google Cloud application with appropriate access to the specified Google Cloud KMS. -
key_ring_location- Google Cloud KMS key ring location. -
key_name- Key Identifier of the Google Cloud KMS key encryption key. -
application_credentials- Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder.
Optional properties
proxy_type- Type of proxy (http/https) if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used. -
port- Authorization server and Google Cloud KMS port number. -
cloudkms_host- Google Cloud KMS host subdomain. -
oauth_host- Open authorization server host name. -
oauth_url- Open authorization URL for the access token. -
privileged_account- Account used to impersonate Google Cloud KMS requests. -
verify_ip- Verify identity of Google Cloud KMS IP address. -
verify_host- Verify the identity of the Google Cloud KMS host name.
Related ONTAP commands
security key-manager external gcp enable
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
application_credentials |
string |
Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder. |
caller_account |
string |
Google Cloud KMS caller account email |
cloudkms_host |
string |
Google Cloud KMS host subdomain. |
ekmip_reachability |
array[ekmip_reachability] |
google_reachability |
Indicates whether or not the Google Cloud KMS is reachable from all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
key_name |
string |
Key Identifier of Google Cloud KMS key encryption key. |
key_ring_location |
string |
Google Cloud KMS key ring location. |
key_ring_name |
string |
Google Cloud KMS key ring name of the deployed Google Cloud application. |
oauth_host |
string |
Open authorization server host name. |
oauth_url |
string |
Open authorization URL for the access token. |
port |
integer |
Authorization server and Google Cloud KMS port number. |
privileged_account |
string |
Google Cloud KMS account to impersonate. |
project_id |
string |
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS. |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster.
svm |
uuid |
string |
A unique identifier for the Google Cloud KMS. |
verify_host |
boolean |
Verify the identity of the Google Cloud KMS host name. |
verify_ip |
boolean |
Verify the identity of the Google Cloud KMS IP address. |
Example request
"application_credentials": "{ type: service_account, project_id: project-id, private_key_id: key-id, private_key: -----BEGIN PRIVATE KEY-----\nprivate-key\n-----END PRIVATE KEY-----\n, client_email: service-account-email, client_id: client-id, auth_uri: https://accounts.google.com/o/oauth2/auth, token_uri: https://accounts.google.com/o/oauth2/token, auth_provider_x509_cert_url: https://www.googleapis.com/oauth2/v1/certs, client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/service-account-email }",
"caller_account": "myaccount@myproject.com",
"cloudkms_host": "cloudkms.googleapis.com",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"google_reachability": {
"code": "346758",
"message": "Google Cloud KMS is not reachable from all nodes - <reason>."
"key_name": "cryptokey1",
"key_ring_location": "global",
"key_ring_name": "gcpapp1-keyring",
"oauth_host": "oauth2.googleapis.com",
"oauth_url": "https://oauth2.googleapis.com/token",
"port": 443,
"privileged_account": "myserviceaccount@myproject.iam.gserviceaccount.com",
"project_id": "gcpapp1",
"proxy_host": "proxy.eng.com",
"proxy_password": "proxypassword",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"code": "346758",
"message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537703 |
The Google Cloud Key Management Service is not supported for the admin Vserver. |
65537704 |
The Google Cloud Key Management Service is not supported in MetroCluster configurations. |
65537706 |
Internal error. Failed to the encrypt the application credentials. |
65537713 |
Internal Error. Failed to store the application credentials. |
65537719 |
Failed to enable the Google Cloud Key Management Service for SVM |
65537720 |
Failed to configure Google Cloud Key Management Service for SVM |
65537740 |
The privileged account must be an email address or an empty string. |
65539703 |
The key manager cannot be configured because the SVM has NAE volumes. |
href |
string |
_links
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
google_reachability
code |
string |
Code corresponding to the error message. Returns a 0 if Google Cloud KMS is reachable from all nodes in the cluster. |
message |
string |
Set to the error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Google Cloud KMS is reachable from all nodes of the cluster. |
state
cluster_state |
boolean |
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster. |
code |
string |
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
name |
string |
uuid |
string |
gcp_kms
_links |
string |
caller_account |
string |
cloudkms_host |
string |
key_name |
string |
key_ring_location |
string |
key_ring_name |
string |
oauth_host |
string |
oauth_url |
string |
port |
integer |
string |
project_id |
string |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
proxy_port |
integer |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
state |
svm |
uuid |
string |
verify_host |
boolean |
verify_ip |
boolean |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
