Create a Google Cloud KMS configuration for an SVM
Configures a Google Cloud KMS for a specified SVM to manage encryption keys securely. Use this configuration to integrate Google Cloud's key management service with your ONTAP environment.
HTTP method and endpoint
POST /security/gcp-kms
Introduced in
ONTAP 9.9
Usage notes
Configures the Google Cloud KMS configuration for the specified SVM.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create a Google Cloud KMS. -
project_id- Google Cloud project (application) ID of the deployed Google Cloud application with appropriate access to the Google Cloud KMS. -
key_ring_name- Google Cloud KMS key ring name of the deployed Google Cloud application with appropriate access to the specified Google Cloud KMS. -
key_ring_location- Google Cloud KMS key ring location. -
key_name- Key Identifier of the Google Cloud KMS key encryption key. -
application_credentials- Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder.
Optional properties
proxy_type`- Type of proxy (http/https) if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used.
Related ONTAP commands
security key-manager external gcp enable
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
application_credentials |
string |
Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder. |
ekmip_reachability |
array[ekmip_reachability] |
key_name |
string |
Key Identifier of Google Cloud KMS key encryption key. |
key_ring_location |
string |
Google Cloud KMS key ring location. |
key_ring_name |
string |
Google Cloud KMS key ring name of the deployed Google Cloud application. |
project_id |
string |
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS. |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
svm |
uuid |
string |
A unique identifier for the Google Cloud KMS. |
Example request
"application_credentials": "{ type: service_account, project_id: project-id, private_key_id: key-id, private_key: -----BEGIN PRIVATE KEY-----\nprivate-key\n-----END PRIVATE KEY-----\n, client_email: service-account-email, client_id: client-id, auth_uri: https://accounts.google.com/o/oauth2/auth, token_uri: https://accounts.google.com/o/oauth2/token, auth_provider_x509_cert_url: https://www.googleapis.com/oauth2/v1/certs, client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/service-account-email }",
"ekmip_reachability": [
"code": 346758,
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"key_name": "cryptokey1",
"key_ring_location": "global",
"key_ring_name": "gcpapp1-keyring",
"project_id": "gcpapp1",
"proxy_host": "proxy.eng.com",
"proxy_password": "proxypassword",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[gcp_kms] |
"records": [
"code": 346758,
"node": {
"name": "node1",
"proxy_port": 1234,
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537703 |
The Google Cloud Key Management Service is not supported for the admin Vserver. |
65537704 |
The Google Cloud Key Management Service is not supported in MetroCluster configurations. |
65537706 |
Internal error. Failed to the encrypt the application credentials. |
65537713 |
Internal Error. Failed to store the application credentials. |
65537719 |
Failed to enable the Google Cloud Key Management Service for SVM |
65537720 |
Failed to configure Google Cloud Key Management Service for SVM |
href |
string |
_links
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
integer |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
google_reachability
Indicates whether or not the Google Cloud KMS service is reachable from all nodes in the cluster.
code |
integer |
Code corresponding to the error message. Returns a 0 if Google Cloud KMS service is reachable from all nodes in the cluster. |
message |
string |
Set to the error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Google Cloud KMS service is reachable from all nodes of the cluster. |
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster.
cluster_state |
boolean |
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster. |
code |
integer |
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
gcp_kms
string |
key_name |
string |
key_ring_location |
string |
key_ring_name |
string |
project_id |
string |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
proxy_port |
integer |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
