Create a Google Cloud KMS configuration for an SVM
Configures the Google Cloud KMS for a specific SVM to manage encryption keys within your ONTAP environment. This setup is essential when integrating Google Cloud's encryption services with your storage management operations.
HTTP method and endpoint
POST /security/gcp-kms
Introduced in
ONTAP 9.9
Usage notes
Configures the Google Cloud KMS configuration for the specified SVM.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create a Google Cloud KMS. -
project_id- Google Cloud project (application) ID of the deployed Google Cloud application with appropriate access to the Google Cloud KMS. -
key_ring_name- Google Cloud KMS key ring name of the deployed Google Cloud application with appropriate access to the specified Google Cloud KMS. -
key_ring_location- Google Cloud KMS key ring location. -
key_name- Key Identifier of the Google Cloud KMS key encryption key. -
application_credentials- The Google Cloud application's service account credentials required to access the specified KMS. This is a JSON file containing an email address and the private key of the service account holder. The field is required if theauthentication_methodis set toapplication_credentials_key.
Optional properties
proxy_type- Type of proxy (http/https) if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used. -
port- Authorization server and Google Cloud KMS port number. -
cloudkms_host- Google Cloud KMS host subdomain. -
oauth_host- Open authorization server host name. -
oauth_url- Open authorization URL for the access token. -
privileged_account- Account used to impersonate Google Cloud KMS requests. -
verify_ip- Verify identity of Google Cloud KMS IP address. -
verify_host- Verify the identity of the Google Cloud KMS host name. -
authentication_method- The authentication method to use for retrieving short lived authentication tokens. -
gce_metadata_server- A custom metadata server URL used for retrieving short lived authentication tokens if the default service account is not used. This is only applicable when theauthentication_methodis set tosa_credentials_attachment.
Related ONTAP commands
security key-manager external gcp enable
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
application_credentials |
string |
The Google Cloud application's service account credentials required to access the specified KMS. The client_email and private_key fields of the service account holder are required. The credentials are required if the |
authentication_method |
string |
Google Cloud KMS authentication method. |
caller_account |
string |
Google Cloud KMS caller account email |
cloudkms_host |
string |
Google Cloud KMS host subdomain. |
ekmip_reachability |
array[ekmip_reachability] |
gce_metadata_server |
string |
A custom metadata server URL used for retrieving short lived authentication tokens if the default service account is not used. This is only applicable when the |
google_reachability |
Indicates whether or not the Google Cloud KMS is reachable from all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
key_name |
string |
Key Identifier of Google Cloud KMS key encryption key. |
key_ring_location |
string |
Google Cloud KMS key ring location. |
key_ring_name |
string |
Google Cloud KMS key ring name of the deployed Google Cloud application. |
oauth_host |
string |
Open authorization server host name. |
oauth_url |
string |
Open authorization URL for the access token. |
port |
integer |
Authorization server and Google Cloud KMS port number. |
privileged_account |
string |
Google Cloud KMS account to impersonate. |
project_id |
string |
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS. |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster.
svm |
uuid |
string |
A unique identifier for the Google Cloud KMS. |
verify_host |
boolean |
Verify the identity of the Google Cloud KMS host name. |
verify_ip |
boolean |
Verify the identity of the Google Cloud KMS IP address. |
Example request
"application_credentials": "{\"private_key\":\"ValidPrivateKey\",\"client_email\":\"my@account.email.com\"}",
"authentication_method": "application_credentials_key",
"caller_account": "myaccount@myproject.com",
"cloudkms_host": "cloudkms.googleapis.com",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"gce_metadata_server": "http://169.254.169.254/computeMetadata/v1/instance/service-accounts/default/token",
"google_reachability": {
"code": "346758",
"message": "Google Cloud KMS is not reachable from all nodes - <reason>."
"key_name": "cryptokey1",
"key_ring_location": "global",
"key_ring_name": "gcpapp1-keyring",
"oauth_host": "oauth2.googleapis.com",
"oauth_url": "https://oauth2.googleapis.com/token",
"port": 443,
"privileged_account": "myserviceaccount@myproject.iam.gserviceaccount.com",
"project_id": "gcpapp1",
"proxy_host": "proxy.eng.com",
"proxy_password": "proxypassword",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"code": "346758",
"message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537703 |
The Google Cloud Key Management Service is not supported for the admin Vserver. |
65537704 |
The Google Cloud Key Management Service is not supported in MetroCluster configurations. |
65537706 |
Internal error. Failed to the encrypt the application credentials. |
65537713 |
Internal Error. Failed to store the application credentials. |
65537719 |
Failed to enable the Google Cloud Key Management Service for SVM |
65537720 |
Failed to configure Google Cloud Key Management Service for SVM |
65537740 |
The privileged account must be an email address or an empty string. |
65537749 |
The application credentials field must be in valid JSON format. |
65537753 |
The "key_name" value contains invalid characters. A forward slash '/' is not allowed in the key name. |
65539704 |
The key manager cannot be configured because the SVM has NAE volumes. |
href |
string |
_links
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
google_reachability
code |
string |
Code corresponding to the error message. Returns a 0 if Google Cloud KMS is reachable from all nodes in the cluster. |
message |
string |
Set to the error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Google Cloud KMS is reachable from all nodes of the cluster. |
state
cluster_state |
boolean |
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster. |
code |
string |
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
name |
string |
uuid |
string |
gcp_kms
_links |
string |
string |
caller_account |
string |
cloudkms_host |
string |
string |
key_name |
string |
key_ring_location |
string |
key_ring_name |
string |
oauth_host |
string |
oauth_url |
string |
port |
integer |
string |
project_id |
string |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
proxy_port |
integer |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
state |
svm |
uuid |
string |
verify_host |
boolean |
verify_ip |
boolean |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
