REST API reference
Add a privilege tuple to an existing role
Adds a privilege tuple, consisting of a REST URI and its access level, to an existing role. This allows you to customize access permissions for specific endpoints.
HTTP method and endpoint
POST /security/roles/{owner.uuid}/{name}/privileges
Introduced in
ONTAP 9.6
Usage notes
Adds a privilege tuple (of REST URI and its access level) to an existing role.
Required parameters
  • owner.uuid - UUID of the SVM that houses this role.
  • name - Name of the role to be updated.
  • path - REST URI path (example: /api/storage/volumes). Can be a resource-qualified endpoint (example: /api/storage/volumes/43256a71-be02-474d-a2a9-9642e12a6a2c/snapshots). Currently, resource-qualified endpoints are limited to the "snapshots" endpoint: /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
  • access - Desired access level for the REST URI path (one of "all", "readonly" or "none").
  • security login rest-role create
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access
string
Access level for the REST endpoint.
path
string
REST URI/endpoint
Example request
  "access": "readonly",
  "path": "/api/storage/volumes"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
5636129
A role with given name has not been defined.
5636143
A Vserver admin cannot use the API with this access level.
5636144
The value specified for the access level is not valid.
5636169
A character in the URI is not valid.
5636170
The URI does not exist.
5636173
This feature requires an effective cluster version of 9.6 or later.
5636175
Vserver admin cannot have access to given API.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
13434890
Vserver-ID failed for Vserver roles.
13434891
UUID LookUp failed for Vserver roles.
13434892
Roles is a required field.
13434893
The SVM does not exist.
string
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
access
string
path
string
REST URI/endpoint
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
