REST API reference
Add a privilege tuple to an existing role
POST /security/roles/{owner.uuid}/{name}/privileges
Introduced In: 9.6
Adds a privilege tuple (of REST URI or command/command directory path, its access level and an optional query, if the "path" refers to a command/command directory path) to an existing role or creates a new role with the provided tuple.
Required parameters
  • owner.uuid - UUID of the SVM that houses this role.
  • name - Name of the role to be updated.
  • path - REST URI path (example: /api/storage/volumes) or command/command directory path (example: snaplock compliance-clock). Can be a resource-qualified endpoint (example: /api/storage/volumes/43256a71-be02-474d-a2a9-9642e12a6a2c/snapshots). Currently, resource-qualified endpoints are limited to the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
In the APIs above, and in the context of REST roles, the wildcard character * can be used in place of {volume.uuid} or {svm.uuid} to represent all volumes or all SVMs, depending on whether the REST endpoint references volumes or SVMs. The {volume.uuid} corresponds to the -instance-uuid field in the output of the "volume show" command at the diagnostic privilege level. It can also be retrieved through the REST endpoint /api/storage/volumes.
  • access - Desired access level for the REST URI path or command/command directory.
  • security login rest-role create
  • security login role create
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
Example request
  "access": "all",
  "path": "volume move start",
  "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1263347
Cannot modify pre-defined roles.
5636129
A role with given name has not been defined.
5636143
A Vserver admin cannot use the API with this access level.
5636144
The value specified for the access level is not valid.
5636168
This role is mapped to a REST role and can only be modified by updating the REST role.
5636262
Cannot create a role with the specified role name because it is reserved by the system.
13434890
Vserver-ID failed for Vserver roles.
13434891
UUID LookUp failed for Vserver roles.
13434892
Roles is a required field.
13434893
The SVM does not exist.
string
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
  • /api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
access
string
path
string
query
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
