REST API reference
Add a privilege tuple to an existing role
Adds a privilege tuple to an existing role, enhancing its capabilities by specifying access levels and optional queries for REST URIs or command paths. This operation is useful when you need to modify role permissions or create a new role with specific privileges.
HTTP method and endpoint
POST /security/roles/{owner.uuid}/{name}/privileges
Introduced in
ONTAP 9.6
Usage notes
Adds a privilege tuple (of REST URI or command/command directory path, its access level and an optional query, if the "path" refers to a command/command directory path) to an existing role or creates a new role with the provided tuple.
Required parameters
  • owner.uuid - UUID of the SVM that houses this role.
  • name - Name of the role to be updated.
  • path - REST URI path (example: /api/storage/volumes) or command/command directory path (example: snaplock compliance-clock). Can be a resource-qualified endpoint (example: /api/storage/volumes/43256a71-be02-474d-a2a9-9642e12a6a2c/snapshots). Currently, resource-qualified endpoints are limited to the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
  • access - Desired access level for the REST URI path or command/command directory.
  • security login rest-role create
  • security login role create
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
Example request
  "access": "all",
  "path": "volume move start",
  "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1263347
Cannot modify pre-defined roles.
5636129
A role with given name has not been defined.
5636143
A Vserver admin cannot use the API with this access level.
5636144
The value specified for the access level is not valid.
5636168
This role is mapped to a rest-role and cannot be modified directly. Modifications must be done with rest-role.
5636169
A character in the URI is not valid.
5636170
The URI does not exist.
5636173
This feature requires an effective cluster version of 9.6 or later.
5636175
Vserver admin cannot have access to given API.
5636184
The expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
5636192
The query parameter cannot be specified for the privileges tuple with API endpoint entries.
5636200
The specified value of the access parameter is invalid, if a command or command directory is specified in the path parameter.
13434890
Vserver-ID failed for Vserver roles.
13434891
UUID LookUp failed for Vserver roles.
13434892
Roles is a required field.
13434893
The SVM does not exist.
string
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
  • /api/protocols/s3/services/{svm.uuid}/users
access
string
path
string
query
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
