Add a privilege tuple to an existing role
POST /security/roles/{owner.uuid}/{name}/privileges
Introduced In: 9.6
Adds a privilege tuple (of REST URI and its access level) to an existing role.
Required parameters
owner.uuid- UUID of the SVM that houses this role. -
name- Name of the role to be updated. -
path- REST URI path (example: "/api/storage/volumes"). -
access- Desired access level for the REST URI path (one of "all", "readonly" or "none").
Related ONTAP commands
security login rest-role create
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
access |
string |
Access level for the REST endpoint. |
path |
string |
REST URI/endpoint |
Example request
"access": "readonly",
"path": "/api/storage/volumes"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636129 |
A role with given name has not been defined. |
5636143 |
A Vserver admin cannot use the API with this access level. |
5636144 |
The value specified for the access level is not valid. |
5636169 |
A character in the URI is not valid. |
5636170 |
The URI does not exist. |
5636173 |
This feature requires an effective cluster version of 9.6 or later. |
5636175 |
Vserver admin cannot have access to given API. |
13434890 |
Vserver-ID failed for Vserver roles. |
13434891 |
UUID LookUp failed for Vserver roles. |
13434892 |
Roles is a required field. |
13434893 |
The SVM does not exist. |
href |
string |
_links
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
access |
string |
path |
string |
REST URI/endpoint |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
