Add a privilege tuple to an existing role
Adds a privilege tuple to an existing role or create a new role with the specified tuple. This is useful for managing access levels and permissions within your storage environment.
HTTP method and endpoint
POST /security/roles/{owner.uuid}/{name}/privileges
Introduced in
ONTAP 9.6
Usage notes
Adds a privilege tuple (of REST URI or command/command directory path, its access level and an optional query, if the "path" refers to a command/command directory path) to an existing role or creates a new role with the provided tuple.
Required parameters
owner.uuid- UUID of the SVM that houses this role. -
name- Name of the role to be updated. -
path- REST URI path (example: /api/storage/volumes) or command/command directory path (example: snaplock compliance-clock). Can be a resource-qualified endpoint (example: /api/storage/volumes/43256a71-be02-474d-a2a9-9642e12a6a2c/snapshots). Currently, resource-qualified endpoints are limited to the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
Artificial Intelligence Data Engine (AIDE) APIs
Data Compute Node (DCN) APIs
– /api/dcn/cluster/nodes/{node.uuid}/metrics
– /api/dcn/network/ports/{port.uuid}/metrics
Data-Engine APIs
– /api/data-engine/policies/{policy.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/acls
– /api/data-engine/workspaces/{workspace.uuid}/data-collections
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/acls
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{entity.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/search
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/versions/{version.uuid}/diffs
– /api/data-engine/workspaces/{workspace.uuid}/data-sources
– /api/data-engine/workspaces/{workspace.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/entities/{entity.uuid}/custom-attributes
– /api/data-engine/workspaces/{workspace.uuid}/queries
– /api/data-engine/workspaces/{workspace.uuid}/queries/{query.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/versions/{version.uuid}/diffs
When used in the context of data collection APIs, {version.uuid} refers to a data collection version. In the context of workspace APIs, it refers to a workspace version.
In the APIs above, and in the context of REST roles, the wildcard character * can be used in place of {volume.uuid} or {svm.uuid} to represent all volumes or all SVMs, depending on whether the REST endpoint references volumes or SVMs. The {volume.uuid} corresponds to the -instance-uuid field in the output of the "volume show" command at the diagnostic privilege level. It can also be retrieved through the REST endpoint /api/storage/volumes.
In the AIDE APIs described above, and in the context of REST roles, the wildcard character * can be used in place of variable components in the Uniform Resource Identifier (URI) path, such as {node.uuid}, {port.uuid}, {policy.uuid}, {workspace.uuid}, {datacollection.uuid}, {entity.uuid}, {version.uuid}, or {query.uuid}. The specific variable to be replaced depends on whether the REST endpoint references nodes, ports, policies, workspaces, data collections, entities, versions, or queries.
However, when using the wildcard character * in place of a variable component in a URI path, it must replace
all variable components in that path. Mixing wildcards and specific values for different variable components within the same URI path is not supported in REST roles. For example, a URI path such as /api/data-engine/workspaces/c6e1b325-4125-11f0-abb5-bc2411f6fd43/data-collections/*/search is not supported.
In summary, only the following two types of resource-qualified endpoints are supported in a REST role:
All variable components in the URI path are specific values. Example: /api/data-engine/workspaces/c6e1b325-4125-11f0-abb5-bc2411f6fd43/data-collections/b09b6d25-4126-11f0-abb5-bc2411f6fd43/search
All variable components in the URI path are wildcards. Example: /api/data-engine/workspaces//data-collections//search
AIDE APIs are supported only in cluster-scoped REST roles, not in SVM-scoped REST roles.
access- Desired access level for the REST URI path or command/command directory.
Related ONTAP commands
security login rest-role create -
security login role create
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
access |
string |
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'. |
path |
string |
Either of REST URI/endpoint OR command/command directory path. |
query |
string |
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute. |
Example request
"access": "all",
"path": "volume move start",
"query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1263347 |
Cannot modify pre-defined roles. |
5636129 |
A role with given name has not been defined. |
5636143 |
A Vserver admin cannot use the API with this access level. |
5636144 |
The value specified for the access level is not valid. |
5636168 |
This role is mapped to a REST role and can only be modified by updating the REST role. |
5636169 |
A character in the URI is not valid. |
5636170 |
The URI does not exist. |
5636173 |
This feature requires an effective cluster version of 9.6 or later. |
5636175 |
Vserver admin cannot have access to given API. |
5636184 |
The expanded REST roles for granular resource control feature is currently disabled. |
5636185 |
The specified UUID was not found. |
5636186 |
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later. |
5636192 |
The query parameter cannot be specified for the privileges tuple with API endpoint entries. |
5636200 |
The specified value of the access parameter is invalid, if a command or command directory is specified in the path parameter. |
5636259 |
The specified child AIDE object was not found within the specified parent AIDE object. |
5636261 |
The specified grandchild AIDE object was not found within the specified child AIDE object that belongs to the specified parent AIDE object. |
5636262 |
Cannot create a role with the specified role name because it is reserved by the system. |
13434890 |
Vserver-ID failed for Vserver roles. |
13434891 |
UUID LookUp failed for Vserver roles. |
13434892 |
Roles is a required field. |
13434893 |
The SVM does not exist. |
href |
string |
_links
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
/api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
access |
string |
path |
string |
query |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
