REST API reference
Delete an IP interface
Deletes an IP interface when you need to remove it from the network configuration. This action is typically performed to decommission or reconfigure network resources.
HTTP method and endpoint
DELETE /network/ip/interfaces/{uuid}
Introduced in
ONTAP 9.6
  • network interface delete
uuid
string
path
True
IP interface UUID
Status: 200, Ok
