REST API reference
Delete an IP interface
Deletes an IP interface to remove network configurations that are no longer needed.
HTTP method and endpoint
DELETE /network/ip/interfaces/{uuid}
Introduced in
ONTAP 9.6
  • network interface delete
uuid
string
path
True
IP interface UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966465
LIF cannot be removed because it is required to maintain quorum on the node.
5376953
The interface is part of one or more portsets. Remove the interface from all portsets before deleting it.
53281039
Failed to delete the interface because it has an associated BGP peer group.
