REST API reference
Delete an IP interface
DELETE /network/ip/interfaces/{uuid}
Introduced In: 9.6
Deletes an IP interface.
  • network interface delete
uuid
string
path
True
IP interface UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966465
LIF cannot be removed because it is required to maintain quorum on the node.
5376953
The interface is part of one or more portsets. Remove the interface from all portsets before deleting it.
53281112
Failed to delete the interface because it has an associated BGP peer group.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
