Delete an IP interface
Deletes an IP interface to remove it from the network configuration. This operation is typically performed when an interface is no longer needed or requires reconfiguration.
HTTP method and endpoint
DELETE /network/ip/interfaces/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
network interface delete
uuid |
string |
path |
True |
IP interface UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966465 |
LIF cannot be removed because it is required to maintain quorum on the node. |
5376953 |
The interface is part of one or more portsets. Remove the interface from all portsets before deleting it. |
53281112 |
Failed to delete the interface because it has an associated BGP peer group. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
