REST API reference
Delete an IP interface
Deletes an IP interface to remove the network configuration associated with it. Use this operation when you need to decommission or reconfigure network resources.
HTTP method and endpoint
DELETE /network/ip/interfaces/{uuid}
Introduced in
ONTAP 9.6
  • network interface delete
uuid
string
path
True
IP interface UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
53281039
Failed to delete the interface because it has an associated BGP peer group.
