Delete an SNMP user
Removes an SNMP user by specifying the relevant engine ID, which can be from the administrative SVM, a data SVM, or the SNMPv3 engine ID of a remote switch. This operation is useful when managing SNMP configurations and access permissions within your network environment.
HTTP method and endpoint
DELETE /support/snmp/users/{engine_id}/{name}
Introduced in
ONTAP 9.7
Usage notes
Deletes an SNMP user. The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
Related ONTAP commands
security login delete -
system snmp community delete
Learn more
engine_id |
string |
path |
True |
Engine ID of owning SVM or remote switch. |
name |
string |
path |
True |
SNMP user name. |
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621475 |
This operation is not allowed on a node SVM. |
2621699 |
This operation is not allowed on a system SVM. |
5636123 |
Cannot create an SNMP user with a role other than readonly, none, or admin. |
5636124 |
Cannot create an SNMP user with a role other than vsadmin-readonly, none, or vsadmin. |
5832712 |
Cannot modify attributes for user "diag." |
7077906 |
Cannot use given role with this SVM because a role with that name has not been defined for the SVM. |
9043999 |
ONTAP failed to create an SNMPv3 user because SNMPv3 is disabled in the cluster. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
