Delete an SNMP user
Removes an SNMP user from your system when you no longer need their access. This action is useful for maintaining security and managing user accounts effectively.
HTTP method and endpoint
DELETE /support/snmp/users/{engine_id}/{name}
Introduced in
ONTAP 9.7
Usage notes
Deletes an SNMP user. The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
Related ONTAP commands
security login delete -
system snmp community delete
Learn more
engine_id |
string |
path |
True |
Engine ID of owning SVM or remote switch. |
name |
string |
path |
True |
SNMP user name. |
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621475 |
This operation is not allowed on a node SVM. |
2621699 |
This operation is not allowed on a system SVM. |
5636123 |
Cannot create an SNMP user with a role other than readonly, none, or admin. |
5636124 |
Cannot create an SNMP user with a role other than vsadmin-readonly, none, or vsadmin. |
5832712 |
Cannot modify attributes for user "diag." |
7077906 |
Cannot use given role with this SVM because a role with that name has not been defined for the SVM. |
9043999 |
ONTAP failed to create an SNMPv3 user because SNMPv3 is disabled in the cluster. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
