REST API reference
Delete an SNMP user
Deletes an SNMP user, which can be associated with an administrative SVM, a data SVM, or a remote switch's SNMPv3 engine ID.
HTTP method and endpoint
DELETE /support/snmp/users/{engine_id}/{name}
Introduced in
ONTAP 9.7
Usage notes
The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
  • security login delete
  • system snmp community delete
engine_id
string
path
True
Engine ID of owning SVM or remote switch.
name
string
path
True
SNMP user name.
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621475
This operation is not allowed on a node SVM.
2621699
This operation is not allowed on a system SVM.
5636123
Cannot create an SNMP user with a role other than readonly, none, or admin.
5636124
Cannot create an SNMP user with a role other than vsadmin-readonly, none, or vsadmin.
5832712
Cannot modify attributes for user "diag."
7077906
Cannot use given role with this SVM because a role with that name has not been defined for the SVM.
9043999
ONTAP failed to create an SNMPv3 user because SNMPv3 is disabled in the cluster.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
