REST API reference
Delete an SNMP user
DELETE /support/snmp/users/{engine_id}/{name}
Introduced In: 9.7
Deletes an SNMP user. The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
  • security login delete
  • system snmp community delete
engine_id
string
path
True
Engine ID of owning SVM or remote switch.
name
string
path
True
SNMP user name.
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
