REST API reference
Delete an SNMP user
Deletes an SNMP user, which is useful when you need to remove outdated or unnecessary SNMP configurations from your system.
HTTP method and endpoint
DELETE /support/snmp/users/{engine_id}/{name}
Introduced in
ONTAP 9.7
Usage notes
The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
  • security login delete
  • system snmp community delete
engine_id
string
path
True
Engine ID of owning SVM or remote switch.
name
string
path
True
SNMP user name.
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
