Retrieve a consistency group Snapshot copy
Retrieves details of a specific snapshot for a consistency group. This is useful when you need to examine the snapshot's characteristics for data management or recovery purposes.
HTTP method and endpoint
GET /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.10
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
is_partial -
missing_voumes.uuid -
missing_voumes.name
consistency_group.uuid |
string |
path |
True |
The unique identifier of the consistency group to retrieve. |
uuid |
string |
path |
True |
The unique identifier of the Snapshot copy of the consistency group to retrieve. |
comment |
string |
query |
False |
Filter by comment |
missing_volumes.name |
string |
query |
False |
Filter by missing_volumes.name |
missing_volumes.uuid |
string |
query |
False |
Filter by missing_volumes.uuid |
snapmirror_label |
string |
query |
False |
Filter by snapmirror_label |
name |
string |
query |
False |
Filter by name |
create_time |
string |
query |
False |
Filter by create_time |
consistency_group.name |
string |
query |
False |
Filter by consistency_group.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
consistency_type |
string |
query |
False |
Filter by consistency_type |
is_partial |
boolean |
query |
False |
Filter by is_partial |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
Comment for the Snapshot copy. |
consistency_group |
The consistency group of the Snapshot copy. |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST. |
create_time |
string |
Time the snapshot copy was created |
is_partial |
boolean |
Indicates whether the Snapshot copy taken is partial or not. |
missing_volumes |
array[volume_reference] |
List of volumes which are not in the Snapshot copy. |
name |
string |
Name of the Snapshot copy. |
snapmirror_label |
string |
Snapmirror Label for the Snapshot copy. |
svm |
uuid |
string |
The unique identifier of the Snapshot copy. The UUID is generated by ONTAP when the Snapshot copy is created.
"href": "/api/resourcelink"
"comment": "My Snapshot copy comment",
"consistency_group": {
"name": "my_consistency_group",
"consistency_type": "crash",
"create_time": "2020-10-25T11:20:00Z",
"is_partial": "",
"missing_volumes": [
"name": "volume1",
"name": "string",
"snapmirror_label": "sm_label",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
consistency_group
_links |
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
_links
self |
volume_reference
_links |
name |
string |
The name of the volume. |
uuid |
string |
svm_reference
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
