Retrieve a consistency group Snapshot copy
Accesses detailed information about a specific snapshot for a consistency group. This is useful for monitoring and managing the state of your storage resources effectively.
HTTP method and endpoint
GET /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves details of a specific snapshot for a consistency group.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
is_partial -
missing_voumes.uuid -
missing_voumes.name
consistency_group.uuid |
string |
path |
True |
The unique identifier of the consistency group to retrieve. |
uuid |
string |
path |
True |
The unique identifier of the Snapshot copy of the consistency group to retrieve. |
missing_volumes.uuid |
string |
query |
False |
Filter by missing_volumes.uuid |
missing_volumes.name |
string |
query |
False |
Filter by missing_volumes.name |
snapshot_volumes.snapshot.name |
string |
query |
False |
Filter by snapshot_volumes.snapshot.name
snapshot_volumes.snapshot.uuid |
string |
query |
False |
Filter by snapshot_volumes.snapshot.uuid
snapshot_volumes.volume.uuid |
string |
query |
False |
Filter by snapshot_volumes.volume.uuid
snapshot_volumes.volume.name |
string |
query |
False |
Filter by snapshot_volumes.volume.name
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
consistency_type |
string |
query |
False |
Filter by consistency_type |
comment |
string |
query |
False |
Filter by comment |
is_partial |
boolean |
query |
False |
Filter by is_partial |
name |
string |
query |
False |
Filter by name |
consistency_group.name |
string |
query |
False |
Filter by consistency_group.name |
create_time |
string |
query |
False |
Filter by create_time |
snapmirror_label |
string |
query |
False |
Filter by snapmirror_label |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
Comment for the Snapshot copy. |
consistency_group |
The consistency group of the Snapshot copy. |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST. |
create_time |
string |
Time the snapshot copy was created |
is_partial |
boolean |
Indicates whether the Snapshot copy taken is partial or not. |
missing_volumes |
array[volume_reference] |
List of volumes which are not in the Snapshot copy. |
name |
string |
Name of the Snapshot copy. |
snapmirror_label |
string |
Snapmirror Label for the Snapshot copy. |
snapshot_volumes |
List of volume and snapshot identifiers for each volume in the Snapshot copy. |
svm |
uuid |
string |
The unique identifier of the Snapshot copy. The UUID is generated by ONTAP when the Snapshot copy is created.
"href": "/api/resourcelink"
"comment": "My Snapshot copy comment",
"consistency_group": {
"name": "my_consistency_group",
"consistency_type": "crash",
"create_time": "2020-10-25T11:20:00Z",
"is_partial": "",
"missing_volumes": [
"name": "volume1",
"name": "string",
"snapmirror_label": "sm_label",
"snapshot_volumes": [
"snapshot": {
"name": "this_snapshot",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
consistency_group
_links |
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
_links
self |
volume_reference
_links |
name |
string |
The name of the volume. |
uuid |
string |
snapshot_reference
_links |
name |
string |
uuid |
string |
consistency_group_volume_snapshot
_links |
snapshot |
volume |
svm_reference
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
