REST API reference
Retrieve a consistency group snapshot
GET /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced In: 9.10
Retrieves details of a specific snapshot for a consistency group.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
  • is_partial
  • missing_volumes.uuid
  • missing_volumes.name
string
path
True
The unique identifier of the consistency group to retrieve.
uuid
string
path
True
The unique identifier of the snapshot of the consistency group to retrieve.
write_fence
boolean
query
False
Filter by write_fence
  • Introduced in: 9.14
snapmirror_label
string
query
False
Filter by snapmirror_label
name
string
query
False
Filter by name
string
query
False
Filter by missing_volumes.name
string
query
False
Filter by missing_volumes.uuid
luns.uuid
string
query
False
Filter by luns.uuid
  • Introduced in: 9.16
luns.name
string
query
False
Filter by luns.name
missing_luns.uuid
string
query
False
Filter by missing_luns.uuid
missing_luns.name
string
query
False
Filter by missing_luns.name
consistency_type
string
query
False
Filter by consistency_type
comment
string
query
False
Filter by comment
missing_namespaces.uuid
string
query
False
Filter by missing_namespaces.uuid
missing_namespaces.name
string
query
False
Filter by missing_namespaces.name
snapshot_volumes.snapshot.name
string
query
False
Filter by snapshot_volumes.snapshot.name
  • Introduced in: 9.12
snapshot_volumes.snapshot.uuid
string
query
False
Filter by snapshot_volumes.snapshot.uuid
snapshot_volumes.volume.name
string
query
False
Filter by snapshot_volumes.volume.name
snapshot_volumes.volume.uuid
string
query
False
Filter by snapshot_volumes.volume.uuid
restore_size
integer
query
False
Filter by restore_size
is_partial
boolean
query
False
Filter by is_partial
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
namespaces.uuid
string
query
False
Filter by namespaces.uuid
namespaces.name
string
query
False
Filter by namespaces.name
consistency_group.name
string
query
False
Filter by consistency_group.name
reclaimable_space
integer
query
False
Filter by reclaimable_space
create_time
string
query
False
Filter by create_time
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
self_link
comment
string
Comment for the snapshot.
consistency_group
consistency_group
The consistency group of the snapshot.
consistency_type
string
Consistency type. This is for categorization purposes only. A snapshot should not be set to 'application consistent' unless the host application is quiesced for the snapshot. Valid in POST.
create_time
string
Time the snapshot copy was created
is_partial
boolean
Indicates whether the snapshot taken is partial or not.
luns
array[luns]
The list of LUNs in this snapshot.
missing_luns
array[lun_reference]
List of LUNs that are not in the snapshot.
missing_namespaces
array[missing_namespaces]
List of NVMe namespaces that are not in the snapshot.
missing_volumes
array[volume_reference]
List of volumes which are not in the snapshot.
name
string
Name of the snapshot.
namespaces
array[namespaces]
The list of NVMe namespaces in this snapshot.
reclaimable_space
integer
Space reclaimed when the snapshot is deleted, in bytes.
restore_size
integer
Size of the consistency group if this snapshot is restored.
snapmirror_label
string
Snapmirror Label for the snapshot.
snapshot_volumes
array[consistency_group_volume_snapshot]
List of volume and snapshot identifiers for each volume in the snapshot.
svm
svm_reference
uuid
string
The unique identifier of the snapshot. The UUID is generated by ONTAP when the snapshot is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
write_fence
boolean
Specifies whether a write fence will be taken when creating the snapshot. The default is false if there is only one volume in the consistency group, otherwise the default is true.
      "href": "/api/resourcelink"
  "comment": "My snapshot comment",
  "consistency_group": {
    "name": "my_consistency_group",
  "consistency_type": "crash",
  "create_time": "2020-10-25 11:20:00 +0000",
  "is_partial": "",
  "luns": [
      "name": "/vol/volume1/lun1",
  "missing_luns": [
  "missing_namespaces": [
      "name": "/vol/volume1/namespace1",
  "missing_volumes": [
      "name": "volume1",
  "name": "string",
  "namespaces": [
  "reclaimable_space": 0,
  "restore_size": 4096,
  "snapmirror_label": "sm_label",
  "snapshot_volumes": [
      "snapshot": {
        "name": "this_snapshot",
      "volume": {
        "name": "volume1",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
consistency_group
_links
self_link
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
self
luns
A reference to a LUN.
_links
_links
name
string
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the LUN.
lun_reference
_links
_links
name
string
uuid
string
missing_namespaces
A reference to a namespace.
_links
_links
name
string
The name of an NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the NVMe namespace.
volume_reference
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
namespaces
_links
_links
name
string
uuid
string
snapshot_reference
_links
_links
name
string
uuid
string
_links
self_link
snapshot
snapshot_reference
volume
volume_reference
svm_reference
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
