Retrieve a consistency group snapshot
Retrieves details of a specific snapshot for a consistency group to review its properties and status.
HTTP method and endpoint
GET /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.10
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
is_partial -
missing_volumes.uuid -
missing_volumes.name
consistency_group.uuid |
string |
path |
True |
The unique identifier of the consistency group to retrieve. |
uuid |
string |
path |
True |
The unique identifier of the snapshot of the consistency group to retrieve. |
snapmirror_label |
string |
query |
False |
Filter by snapmirror_label |
is_partial |
boolean |
query |
False |
Filter by is_partial |
restore_size |
integer |
query |
False |
Filter by restore_size
comment |
string |
query |
False |
Filter by comment |
luns.uuid |
string |
query |
False |
Filter by luns.uuid
luns.name |
string |
query |
False |
Filter by luns.name
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
reclaimable_space |
integer |
query |
False |
Filter by reclaimable_space
consistency_group.name |
string |
query |
False |
Filter by consistency_group.name |
snapshot_volumes.snapshot.name |
string |
query |
False |
Filter by snapshot_volumes.snapshot.name
snapshot_volumes.snapshot.uuid |
string |
query |
False |
Filter by snapshot_volumes.snapshot.uuid
snapshot_volumes.volume.uuid |
string |
query |
False |
Filter by snapshot_volumes.volume.uuid
snapshot_volumes.volume.name |
string |
query |
False |
Filter by snapshot_volumes.volume.name
write_fence |
boolean |
query |
False |
Filter by write_fence
consistency_type |
string |
query |
False |
Filter by consistency_type |
missing_namespaces.uuid |
string |
query |
False |
Filter by missing_namespaces.uuid
missing_namespaces.name |
string |
query |
False |
Filter by missing_namespaces.name
missing_luns.uuid |
string |
query |
False |
Filter by missing_luns.uuid
missing_luns.name |
string |
query |
False |
Filter by missing_luns.name
name |
string |
query |
False |
Filter by name |
missing_volumes.uuid |
string |
query |
False |
Filter by missing_volumes.uuid |
missing_volumes.name |
string |
query |
False |
Filter by missing_volumes.name |
create_time |
string |
query |
False |
Filter by create_time |
namespaces.uuid |
string |
query |
False |
Filter by namespaces.uuid
namespaces.name |
string |
query |
False |
Filter by namespaces.name
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
Comment for the snapshot. |
consistency_group |
The consistency group of the snapshot. |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A snapshot should not be set to 'application consistent' unless the host application is quiesced for the snapshot. Valid in POST. |
create_time |
string |
Time the snapshot copy was created |
is_partial |
boolean |
Indicates whether the snapshot taken is partial or not. |
luns |
array[luns] |
The list of LUNs in this snapshot. |
missing_luns |
array[lun_reference] |
List of LUNs that are not in the snapshot. |
missing_namespaces |
array[missing_namespaces] |
List of NVMe namespaces that are not in the snapshot. |
missing_volumes |
array[volume_reference] |
List of volumes which are not in the snapshot. |
name |
string |
Name of the snapshot. |
namespaces |
array[namespaces] |
The list of NVMe namespaces in this snapshot. |
reclaimable_space |
integer |
Space reclaimed when the snapshot is deleted, in bytes. |
restore_size |
integer |
Size of the consistency group if this snapshot is restored. |
snapmirror_label |
string |
Snapmirror Label for the snapshot. |
snapshot_volumes |
List of volume and snapshot identifiers for each volume in the snapshot. |
svm |
uuid |
string |
The unique identifier of the snapshot. The UUID is generated by ONTAP when the snapshot is created.
write_fence |
boolean |
Specifies whether a write fence will be taken when creating the snapshot. The default is false if there is only one volume in the consistency group, otherwise the default is true. |
"href": "/api/resourcelink"
"comment": "My snapshot comment",
"consistency_group": {
"name": "my_consistency_group",
"consistency_type": "crash",
"create_time": "2020-10-25 07:20:00 -0400",
"is_partial": "",
"luns": [
"name": "/vol/volume1/lun1",
"missing_luns": [
"missing_namespaces": [
"name": "/vol/volume1/namespace1",
"missing_volumes": [
"name": "volume1",
"name": "string",
"namespaces": [
"reclaimable_space": 0,
"restore_size": 4096,
"snapmirror_label": "sm_label",
"snapshot_volumes": [
"snapshot": {
"name": "this_snapshot",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
consistency_group
_links |
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
_links
self |
luns
A reference to a LUN.
_links |
name |
string |
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume. LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
uuid |
string |
The unique identifier of the LUN. |
lun_reference
_links |
name |
string |
uuid |
string |
missing_namespaces
A reference to a namespace.
_links |
name |
string |
The name of an NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume. NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
uuid |
string |
The unique identifier of the NVMe namespace. |
volume_reference
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
namespaces
_links |
name |
string |
uuid |
string |
snapshot_reference
_links |
name |
string |
uuid |
string |
consistency_group_volume_snapshot
_links |
snapshot |
volume |
svm_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
