REST API reference
Retrieve a consistency group Snapshot copy
Retrieves details of a specific snapshot for a consistency group to access the snapshot information efficiently.
HTTP method and endpoint
GET /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.10
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
  • is_partial
  • missing_voumes.uuid
  • missing_voumes.name
string
path
True
The unique identifier of the consistency group to retrieve.
uuid
string
path
True
The unique identifier of the Snapshot copy of the consistency group to retrieve.
name
string
query
False
Filter by name
consistency_type
string
query
False
Filter by consistency_type
comment
string
query
False
Filter by comment
create_time
string
query
False
Filter by create_time
consistency_group.name
string
query
False
Filter by consistency_group.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
is_partial
boolean
query
False
Filter by is_partial
missing_volumes.uuid
string
query
False
Filter by missing_volumes.uuid
missing_volumes.name
string
query
False
Filter by missing_volumes.name
snapshot_volumes.snapshot.name
string
query
False
Filter by snapshot_volumes.snapshot.name
  • Introduced in: 9.12
snapshot_volumes.snapshot.uuid
string
query
False
Filter by snapshot_volumes.snapshot.uuid
snapshot_volumes.volume.uuid
string
query
False
Filter by snapshot_volumes.volume.uuid
snapshot_volumes.volume.name
string
query
False
Filter by snapshot_volumes.volume.name
snapmirror_label
string
query
False
Filter by snapmirror_label
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
self_link
comment
string
Comment for the Snapshot copy.
consistency_group
consistency_group
The consistency group of the Snapshot copy.
consistency_type
string
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST.
create_time
string
Time the snapshot copy was created
is_partial
boolean
Indicates whether the Snapshot copy taken is partial or not.
missing_volumes
array[volume_reference]
List of volumes which are not in the Snapshot copy.
name
string
Name of the Snapshot copy.
snapmirror_label
string
Snapmirror Label for the Snapshot copy.
snapshot_volumes
array[consistency_group_volume_snapshot]
List of volume and snapshot identifiers for each volume in the Snapshot copy.
svm
svm_reference
uuid
string
The unique identifier of the Snapshot copy. The UUID is generated by ONTAP when the Snapshot copy is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
      "href": "/api/resourcelink"
  "comment": "My Snapshot copy comment",
  "consistency_group": {
    "name": "my_consistency_group",
  "consistency_type": "crash",
  "create_time": "2020-10-25 11:20:00 +0000",
  "is_partial": "",
  "missing_volumes": [
      "name": "volume1",
  "name": "string",
  "snapmirror_label": "sm_label",
  "snapshot_volumes": [
      "snapshot": {
        "name": "this_snapshot",
      "volume": {
        "name": "volume1",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
consistency_group
_links
self_link
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
self
volume_reference
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snapshot_reference
_links
_links
name
string
uuid
string
_links
self_link
snapshot
snapshot_reference
volume
volume_reference
svm_reference
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
