REST API reference
Updates a host cache setting
  • returns success in case no values are provided for update # related ontap commands
    • vserver services name-service cache hosts settings modify # learn more
    • [doc /name-services/cache/host/settings](#docs-name-services-name-services_cache_host_settings)
PATCH /name-services/cache/host/settings/{svm.uuid}
Introduced In: 9.11
Updates a host cache setting.
Important notes
  • svm.uuid field cannot be empty.
  • Returns success in case no values are provided for update.
svm.uuid
string
path
True
SVM UUID.
Request Body
Name Type Description
dns_ttl_enabled
boolean
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used.
enabled
boolean
Indicates whether or not the cache is enabled.
negative_cache_enabled
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl
string
Specifies negative Time to Live, in ISO 8601 format.
svm
svm
ttl
string
Specifies Time to Live (TTL), in ISO 8601 format.
Example request
  "dns_ttl_enabled": 1,
  "negative_ttl": "PT5M",
  "svm": {
    "name": "svm1",
  "ttl": "PT24H"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
23724055
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support.
string
svm
name
string
The name of the SVM.
uuid
string
hosts_settings
Hosts cache setting.
dns_ttl_enabled
boolean
enabled
boolean
boolean
negative_ttl
string
svm
svm
ttl
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
