Update a host cache setting
Updates a host cache setting to modify the current configuration for caching host information. Use this endpoint when you need to adjust cache settings to suit specific performance requirements.
HTTP method and endpoint
PATCH /name-services/cache/host/settings/{uuid}
Introduced in
ONTAP 9.14
Important notes
UUID field cannot be empty.
Returns success in case no values are provided for update.
Related ONTAP commands
vserver services name-service cache hosts settings modify
Learn more
uuid |
string |
path |
True |
UUID for the host record. |
Request Body
| Name | Type | Description |
dns_ttl_enabled |
boolean |
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used. |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
negative_cache_enabled |
boolean |
Indicates whether or not the negative cache is enabled. |
negative_ttl |
string |
Specifies negative Time to Live, in ISO 8601 format. |
svm |
ttl |
string |
Specifies Time to Live (TTL), in ISO 8601 format. |
uuid |
string |
Example request
"dns_ttl_enabled": 1,
"negative_ttl": "PT5M",
"svm": {
"name": "svm1",
"ttl": "PT24H",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724055 |
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support. |
href |
string |
_links
svm
name |
string |
uuid |
string |
hosts_settings
Hosts cache setting.
dns_ttl_enabled |
boolean |
enabled |
boolean |
boolean |
negative_ttl |
string |
svm |
ttl |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
