Update a host cache setting
Updates the host cache setting, modifying the configuration to meet your specific requirements for managing cache behavior on the host.
HTTP method and endpoint
PATCH /name-services/cache/host/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Important notes
svm.uuid field cannot be empty.
Returns success in case no values are provided for update.
Related ONTAP commands
vserver services name-service cache hosts settings modify
Learn more
svm.uuid |
string |
path |
True |
SVM UUID. |
Request Body
| Name | Type | Description |
dns_ttl_enabled |
boolean |
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used. |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
negative_cache_enabled |
boolean |
Indicates whether or not the negative cache is enabled. |
negative_ttl |
string |
Specifies negative Time to Live, in ISO 8601 format. |
svm |
ttl |
string |
Specifies Time to Live (TTL), in ISO 8601 format. |
Example request
"dns_ttl_enabled": 1,
"negative_ttl": "PT5M",
"svm": {
"name": "svm1",
"ttl": "PT24H"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724055 |
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
hosts_settings
Hosts cache setting.
dns_ttl_enabled |
boolean |
enabled |
boolean |
boolean |
negative_ttl |
string |
svm |
ttl |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
