Update a host cache setting
Updates a host cache setting to modify its configuration based on your requirements. Use this endpoint when you need to adjust or optimize host cache settings in your system.
HTTP method and endpoint
PATCH /name-services/cache/host/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Important notes
svm.uuid field cannot be empty.
Returns success in case no values are provided for update.
Related ONTAP commands
vserver services name-service cache hosts settings modify
Learn more
svm.uuid |
string |
path |
True |
SVM UUID. |
Request Body
| Name | Type | Description |
dns_ttl_enabled |
boolean |
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used. |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
negative_cache_enabled |
boolean |
Indicates whether or not the negative cache is enabled. |
negative_ttl |
string |
Specifies negative Time to Live, in ISO 8601 format. |
svm |
ttl |
string |
Specifies Time to Live (TTL), in ISO 8601 format. |
Example request
"dns_ttl_enabled": 1,
"negative_ttl": "PT5M",
"svm": {
"name": "svm1",
"ttl": "PT24H"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724055 |
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
hosts_settings
Hosts cache setting.
dns_ttl_enabled |
boolean |
enabled |
boolean |
boolean |
negative_ttl |
string |
svm |
ttl |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
