REST API reference
Update a host cache setting
Updates a host cache setting to modify the current configuration for caching host information. Use this endpoint when you need to adjust cache settings to suit specific performance requirements.
HTTP method and endpoint
PATCH /name-services/cache/host/settings/{uuid}
Introduced in
ONTAP 9.14
Important notes
  • UUID field cannot be empty.
  • Returns success in case no values are provided for update.
  • vserver services name-service cache hosts settings modify
uuid
string
path
True
UUID for the host record.
Request Body
Name Type Description
dns_ttl_enabled
boolean
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used.
enabled
boolean
Indicates whether or not the cache is enabled.
negative_cache_enabled
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl
string
Specifies negative Time to Live, in ISO 8601 format.
svm
svm
ttl
string
Specifies Time to Live (TTL), in ISO 8601 format.
uuid
string
Example request
  "dns_ttl_enabled": 1,
  "negative_ttl": "PT5M",
  "svm": {
    "name": "svm1",
  "ttl": "PT24H",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
23724055
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support.
string
svm
name
string
uuid
string
hosts_settings
Hosts cache setting.
dns_ttl_enabled
boolean
enabled
boolean
boolean
negative_ttl
string
svm
svm
ttl
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
