Update the maximum split load
PATCH /storage/file/clone/split-loads/{node.uuid}
Introduced In: 9.10
Updates the maximum split load.
Related Ontap command
volume file clone split load modify
Learn More
DOC /storage/file/clone]
# The call:
curl -X PATCH "https://<mgmt_IP>/api/storage/file/clone/split-loads/9686b8d1-a828-11eb-80d8-005056bbe7b6" -d '{"load": {"maximum": "16TB" } }'
# The response to successful patch is empty body
node.uuid  |
string  |
path  |
True  |
Node UUID  |
Request Body
| Name | Type | Description |
load  |
node  |
Example request
  "load": {
    "allowable": 0,
    "current": 0,
    "token_reserved": 0
  "node": {
    "name": "node1",
Status: 200, Ok
Status: Default, Error
href  |
string  |
self_link
load
allowable  |
integer  |
Specifies the available file clone split load on the node.  |
current  |
integer  |
Specifies the current on-going file clone split load on the node.  |
maximum  |
integer  |
Specifies the maximum allowable file clone split load on the node at any point in time.  |
token_reserved  |
integer  |
Specifies the file clone split load on the node reserved for tokens.  |
_links
node_reference
name  |
string  |
uuid  |
string  |
split_load
load  |
node  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
