Update the maximum split load
PATCH /storage/file/clone/split-loads/{node.uuid}
Introduced In: 9.10
Updates the maximum split load.
Related Ontap command
volume file clone split load modify
Learn More
DOC /storage/file/clone]
# The call:
curl -X PATCH "https://<mgmt_IP>/api/storage/file/clone/split-loads/9686b8d1-a828-11eb-80d8-005056bbe7b6" -d '{"load": {"maximum": "16TB" } }'
# The response to successful patch is empty body
node.uuid |
string |
path |
True |
Node UUID |
Request Body
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13565966 |
Failed to modify the maximum split load on the node due to an invalid field value. |
| Name | Type | Description |
href |
string |
self_link
load
allowable |
integer |
Specifies the available file clone split load on the node. |
current |
integer |
Specifies the current on-going file clone split load on the node. |
maximum |
integer |
Specifies the maximum allowable file clone split load on the node at any point in time. The least allowable file clone split load is 4KB and the maximum is 675TB. The default file clone split load is set based on the system configuration. |
token_reserved |
integer |
Specifies the file clone split load on the node reserved for tokens. |
_links
node
name |
string |
uuid |
string |
split_load
load |
node |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
