Update the maximum split load
Updates the maximum split load for a file clone to manage resource allocation effectively. This is useful when adjusting the workload distribution for performance optimization.
HTTP method and endpoint
PATCH /storage/file/clone/split-loads/{node.uuid}
Introduced in
ONTAP 9.10
Related Ontap command
volume file clone split load modify
Learn More
DOC /storage/file/clone]
# The call:
curl -X PATCH "https://<mgmt_IP>/api/storage/file/clone/split-loads/9686b8d1-a828-11eb-80d8-005056bbe7b6" -d '{"load": {"maximum": "16TB" } }'
# The response to successful patch is empty body
node.uuid |
string |
path |
True |
Node UUID |
Request Body
| Name | Type | Description |
load |
node |
Example request
"load": {
"allowable": 0,
"current": 0,
"token_reserved": 0
"node": {
"name": "node1",
Status: 200, Ok
Status: Default, Error
href |
string |
self_link
load
allowable |
integer |
Specifies the available file clone split load on the node. |
current |
integer |
Specifies the current on-going file clone split load on the node. |
maximum |
integer |
Specifies the maximum allowable file clone split load on the node at any point in time. |
token_reserved |
integer |
Specifies the file clone split load on the node reserved for tokens. |
_links
node_reference
name |
string |
uuid |
string |
split_load
load |
node |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
