REST API reference
Update the maximum split load
Updates the maximum split load for a file clone operation, adjusting the load capacity to meet specific storage requirements.
HTTP method and endpoint
PATCH /storage/file/clone/split-loads/{node.uuid}
Introduced in
ONTAP 9.10
  • volume file clone split load modify
Learn More
  • [DOC /storage/file/clone]
# The call:
curl -X PATCH "https://<mgmt_IP>/api/storage/file/clone/split-loads/9686b8d1-a828-11eb-80d8-005056bbe7b6" -d '{"load": {"maximum": "16TB" } }'
# The response to successful patch is empty body
node.uuid
string
path
True
Node UUID
Request Body
Name Type Description
load
load
node
node
Example request
  "load": {
    "allowable": "4KB",
    "current": 0,
    "maximum": "4KB",
    "token_reserved": 0
  "node": {
    "name": "node1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
13565966
Failed to modify the maximum split load on the node due to an invalid field value.
string
load
allowable
integer
Specifies the available file clone split load on the node.
current
integer
Specifies the current on-going file clone split load on the node.
maximum
integer
Specifies the maximum allowable file clone split load on the node at any point in time. The least allowable file clone split load is 4KB and the maximum is 675TB. The default value is 4KB for the maximum split load when unit is not specified. The default file clone split load is set based on the system configuration.
token_reserved
integer
Specifies the file clone split load on the node reserved for tokens.
node
name
string
uuid
string
split_load
load
load
node
node
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
