REST API reference
Update the maximum split load
PATCH /storage/file/clone/split-loads/{node.uuid}
Introduced In: 9.10
Updates the maximum split load.
  • volume file clone split load modify
Learn More
  • [DOC /storage/file/clone]
# The call:
curl -X PATCH "https://<mgmt_IP>/api/storage/file/clone/split-loads/9686b8d1-a828-11eb-80d8-005056bbe7b6" -d '{"load": {"maximum": "16TB" } }'
# The response to successful patch is empty body
node.uuid
string
path
True
Node UUID
Request Body
Name Type Description
load
load
node
node_reference
Example request
  "load": {
    "allowable": 0,
    "current": 0,
    "token_reserved": 0
  "node": {
    "name": "node1",
Status: 200, Ok
Status: Default, Error
string
load
allowable
integer
Specifies the available file clone split load on the node.
current
integer
Specifies the current on-going file clone split load on the node.
maximum
integer
Specifies the maximum allowable file clone split load on the node at any point in time.
token_reserved
integer
Specifies the file clone split load on the node reserved for tokens.
node_reference
name
string
uuid
string
split_load
load
load
node
node_reference
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
