Create a clone of the file
Creates a clone of a specified file within a volume to replicate or back up data without altering the original file. This operation is useful when you need to create backups or manage storage efficiently by replicating file data into different locations or configurations.
HTTP method and endpoint
POST /storage/file/clone
Introduced in
ONTAP 9.6
Usage notes
Creates a clone of the file.
Required Properties
source_path -
destination_path -
volume.uuidandvolume.name- Instance UUID and name of volume in which to create clone.
Optional Properties
range- Required only in the case of a sub file clone. -
autodelete- Marks a cloned file for auto deletion. -
backup- Cloned file is used as a backup.
Related Ontap commands
volume file clone create
Creating file clones
The POST operation is used to create file clones with the specified attributes in body. Set the volume.name and volume.uuid to identify the volume.
Set source_path and destination_path to identify the file path of original and copied file. In case of full file clone, the new file is created using destination_path.<br>
In case of a sub file clone, set range in the format source-file-block-number:destination-file-block-number:block-count. The API returns an error for the following overlapping conditions: (a) if source and destination files are same and any of the source ranges overlap with any of the destination ranges. (b) if any of the source ranges overlap amongst themselves. (c) if any of the destination ranges overlap amongst themselves. If not provided, full file cloning is assumed.
If set to autodelete, the cloned file is deleted when the volumes are full.<br>
# The API:
curl -X POST "https://<mgmt_ip>/api/storage/file/clone" -H "accept: application/hal+json" -d '{"volume": {"name": "vol1", "uuid": "40e0fdc5-c28f-11eb-8270-005056bbeb0b"}, "source_path": "f1", "destination_path": "f2_c1"}'
# The response:
"job": {
"uuid": "0d025fd9-c4dc-11eb-adb5-005056bbeb0b",
"href": "/api/cluster/jobs/0d025fd9-c4dc-11eb-adb5-005056bbeb0b"
Learn More
DOC /storage/file/clone]
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
autodelete |
boolean |
Mark clone file for auto deletion. |
destination_path |
string |
Relative path of the clone/destination file in the volume. |
is_backup |
boolean |
Mark clone file for backup. |
overwrite_destination |
boolean |
Destination file gets overwritten. |
range |
array[string] |
List of block ranges for sub-file cloning in the format "source-file-block-number:destination-file-block-number:block-count" |
source_path |
string |
Relative path of the source file in the volume. |
token_uuid |
string |
UUID of existing clone token with reserved split load. |
volume |
Example request
"destination_path": "dest_file1, dir1/dest_file2",
"range": [
"10:10:5",
"20:20:10"
"source_path": "src_file1, dir1/src_file2, ./.snapshot/snap1/src_file3",
"token_uuid": "string",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
_links
volume
name |
string |
The name of the volume. |
uuid |
string |
file_clone
File clone
autodelete |
boolean |
destination_path |
string |
is_backup |
boolean |
boolean |
range |
array[string] |
source_path |
string |
token_uuid |
string |
volume |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
