Create a clone of the file
Creates a clone of a file, specifying attributes like source and destination paths. This operation is useful for tasks such as backing up data or working with file versions without altering the original file.
HTTP method and endpoint
POST /storage/file/clone
Introduced in
ONTAP 9.6
Required Properties
source_path -
destination_path -
volume.uuid- Instance UUID of the volume in which to create clone.
Optional Properties
range- Required only in the case of a sub file clone. -
autodelete- Marks a cloned file for auto deletion. -
is_backup- Cloned file is used as a backup. -
volume.name- Name of the volume in which to create the clone. -
token_uuid- UUID of existing clone token.
Related Ontap commands
volume file clone create
Creating file clones
The POST operation is used to create file clones with the specified attributes in the body. Set the volume.uuid to identify the volume.
Set source_path and destination_path to identify the file path of the original and copied file. For a full file clone, the new file is created using destination_path.
For a sub file clone, set range in the format source-file-block-number:destination-file-block-number:block-count. The API returns an error for the following overlapping conditions: (a) if the source and destination files are the same and if any of the source ranges overlap with any of the destination ranges. (b) if any of the source ranges overlap amongst themselves. (c) if any of the destination ranges overlap amongst themselves. If not provided, full file cloning is assumed.
If set to autodelete, the cloned file is deleted when the volumes are full.<br>
# The API:
curl -X POST "https://<mgmt_ip>/api/storage/file/clone" -H "accept: application/hal+json" -d '{"volume": {"name": "vol1", "uuid": "40e0fdc5-c28f-11eb-8270-005056bbeb0b"}, "source_path": "f1", "destination_path": "f2_c1"}'
# The response:
"job": {
"uuid": "0d025fd9-c4dc-11eb-adb5-005056bbeb0b",
"href": "/api/cluster/jobs/0d025fd9-c4dc-11eb-adb5-005056bbeb0b"
Learn More
DOC /storage/file/clone]
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
autodelete |
boolean |
Mark clone file for auto deletion. |
destination_path |
string |
Relative path of the clone/destination file in the volume. |
is_backup |
boolean |
Mark clone file for backup. |
overwrite_destination |
boolean |
Destination file gets overwritten. |
range |
array[string] |
List of block ranges for sub-file cloning in the format "source-file-block-number:destination-file-block-number:block-count" |
source_path |
string |
Relative path of the source file in the volume. |
token_uuid |
string |
UUID of existing clone token with reserved split load. |
volume |
Example request
"destination_path": "dest_file1 or dir1/dest_file2",
"is_backup": "",
"range": [
2
"source_path": "src_file1 or dir1/src_file2 or ./.snapshot/snap1/src_file3",
"token_uuid": "string",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
917864 |
Failed to get the file handle. |
917898 |
Invalid |
918236 |
The specified |
13565952 |
Clone start failed. |
13565988 |
The destination file cannot be marked as a backup clone as only a full-file clone can be a backup clone. |
href |
string |
_links
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
file_clone
File clone
autodelete |
boolean |
destination_path |
string |
is_backup |
boolean |
boolean |
range |
array[string] |
source_path |
string |
token_uuid |
string |
volume |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
