REST API reference
Create a clone of the file
Creates a clone of a file to duplicate data within a specified volume. This operation supports both full and sub-file cloning, facilitating backup or data management workflows.
HTTP method and endpoint
POST /storage/file/clone
Introduced in
ONTAP 9.6
Required Properties
  • source_path
  • destination_path
  • volume.uuid and volume.name - Instance UUID and name of volume in which to create clone.
Optional Properties
  • range - Required only in the case of a sub file clone.
  • autodelete - Marks a cloned file for auto deletion.
  • backup - Cloned file is used as a backup.
  • volume file clone create
Creating file clones
The POST operation is used to create file clones with the specified attributes in body. Set the volume.name and volume.uuid to identify the volume.
Set source_path and destination_path to identify the file path of original and copied file. In case of full file clone, the new file is created using destination_path.<br> In case of a sub file clone, set range in the format source-file-block-number:destination-file-block-number:block-count. The API returns an error for the following overlapping conditions: (a) if source and destination files are same and any of the source ranges overlap with any of the destination ranges. (b) if any of the source ranges overlap amongst themselves. (c) if any of the destination ranges overlap amongst themselves. If not provided, full file cloning is assumed.
If set to autodelete, the cloned file is deleted when the volumes are full.<br>
# The API:
curl -X POST "https://<mgmt_ip>/api/storage/file/clone" -H "accept: application/hal+json" -d '{"volume": {"name": "vol1",  "uuid": "40e0fdc5-c28f-11eb-8270-005056bbeb0b"}, "source_path": "f1", "destination_path": "f2_c1"}'
# The response:
"job": {
  "uuid": "0d025fd9-c4dc-11eb-adb5-005056bbeb0b",
       "href": "/api/cluster/jobs/0d025fd9-c4dc-11eb-adb5-005056bbeb0b"
Learn More
  • [DOC /storage/file/clone]
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
autodelete
boolean
Mark clone file for auto deletion.
destination_path
string
Relative path of the clone/destination file in the volume.
is_backup
boolean
Mark clone file for backup.
overwrite_destination
boolean
Destination file gets overwritten.
range
array[string]
List of block ranges for sub-file cloning in the format "source-file-block-number:destination-file-block-number:block-count"
source_path
string
Relative path of the source file in the volume.
token_uuid
string
UUID of existing clone token with reserved split load.
volume
volume
Example request
  "destination_path": "dest_file1, dir1/dest_file2",
  "range": [
    36605,
    73210
  "source_path": "src_file1, dir1/src_file2, ./.snapshot/snap1/src_file3",
  "token_uuid": "string",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default, Error
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
file_clone
File clone
autodelete
boolean
destination_path
string
is_backup
boolean
boolean
range
array[string]
source_path
string
token_uuid
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
