REST API reference
Create a clone of the file
Creates a clone of a specified file to work with an exact copy without affecting the original file.
HTTP method and endpoint
POST /storage/file/clone
Introduced in
ONTAP 9.6
Usage notes
Creates a clone of the file.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
autodelete
boolean
Mark clone file for auto deletion.
destination_path
string
Relative path of the clone/destination file in the volume.
is_backup
boolean
Mark clone file for backup.
overwrite_destination
boolean
Destination file gets overwritten.
range
array[string]
List of block ranges for sub-file cloning in the format "source-file-block-number:destination-file-block-number:block-count"
source_path
string
Relative path of the source file in the volume.
volume
volume
Example request
  "destination_path": "dest_file1, dir1/dest_file2",
  "range": [
    "10:10:5",
    "20:20:10"
  "source_path": "src_file1, dir1/src_file2, ./.snapshot/snap1/src_file3",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
file_clone
File clone
autodelete
boolean
destination_path
string
is_backup
boolean
boolean
range
array[string]
source_path
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
