REST API reference
Create a clone of the file
Creates a clone of a file to duplicate its contents within the specified volume. Use this operation to manage file versions, facilitate backups, or set up a new file for specific purposes without altering the original.
HTTP method and endpoint
POST /storage/file/clone
Introduced in
ONTAP 9.6
Required Properties
  • source_path
  • destination_path
  • volume.uuid - Instance UUID of the volume in which to create clone.
Optional Properties
  • range - Required only in the case of a sub file clone.
  • autodelete - Marks a cloned file for auto deletion.
  • is_backup - Cloned file is used as a backup.
  • volume.name - Name of the volume in which to create the clone.
  • token_uuid - UUID of existing clone token.
  • volume file clone create
Creating file clones
The POST operation is used to create file clones with the specified attributes in the body. Set the volume.uuid to identify the volume. Set source_path and destination_path to identify the file path of the original and copied file. For a full file clone, the new file is created using destination_path. For a sub file clone, set range in the format source-file-block-number:destination-file-block-number:block-count. The API returns an error for the following overlapping conditions: (a) if the source and destination files are the same and if any of the source ranges overlap with any of the destination ranges. (b) if any of the source ranges overlap amongst themselves. (c) if any of the destination ranges overlap amongst themselves. If not provided, full file cloning is assumed.
If set to autodelete, the cloned file is deleted when the volumes are full.<br>
# The API:
curl -X POST "https://<mgmt_ip>/api/storage/file/clone" -H "accept: application/hal+json" -d '{"volume": {"name": "vol1",  "uuid": "40e0fdc5-c28f-11eb-8270-005056bbeb0b"}, "source_path": "f1", "destination_path": "f2_c1"}'
# The response:
"job": {
  "uuid": "0d025fd9-c4dc-11eb-adb5-005056bbeb0b",
       "href": "/api/cluster/jobs/0d025fd9-c4dc-11eb-adb5-005056bbeb0b"
Learn More
  • [DOC /storage/file/clone]
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
autodelete
boolean
Mark clone file for auto deletion.
destination_path
string
Relative path of the clone/destination file in the volume.
is_backup
boolean
Mark clone file for backup.
overwrite_destination
boolean
Destination file gets overwritten.
range
array[string]
List of block ranges for sub-file cloning in the format "source-file-block-number:destination-file-block-number:block-count"
source_path
string
Relative path of the source file in the volume.
token_uuid
string
UUID of existing clone token with reserved split load.
volume
volume
Example request
  "destination_path": "dest_file1 or dir1/dest_file2",
  "is_backup": "",
  "range": [
    2
  "source_path": "src_file1 or dir1/src_file2 or ./.snapshot/snap1/src_file3",
  "token_uuid": "string",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
917812
A relative path must be used for destination_path when a volume is specified.
917864
Failed to get the file handle.
917898
Invalid value for the field -range. Value must be provided in the format <source start block>:<destination start block>:<block length>.
918236
The specified volume.uuid and volume.name refer to different volumes.
13565952
Clone start failed.
13565988
The destination file cannot be marked as a backup clone as only a full-file clone can be a backup clone.
13565998
File clone using autodelete is not supported on a FlexGroup volume. Try the operation again without specifying the "autodelete" parameter.
string
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
file_clone
File clone
autodelete
boolean
destination_path
string
is_backup
boolean
boolean
range
array[string]
source_path
string
token_uuid
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
