REST API reference
Delete a volume Snapshot copy
Deletes a volume Snapshot copy to remove a specific snapshot from your storage system. Use this operation when you need to free up space or manage snapshot retention policies.
HTTP method and endpoint
DELETE /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
  • snapshot delete
volume.uuid
string
path
True
Volume UUID
uuid
string
path
True
Snapshot copy UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default
ONTAP Error Response Code
Error Code Description
2
An invalid value was entered for one of the fields.
1638521
Snapshot copies can only be deleted on read/write (RW) volumes.
1638538
Cannot determine the status of the Snapshot copy delete operation for the specified volume.
1638543
Failed to delete Snapshot copy because it has an owner.
1638555
The specified Snapshot copy has not expired or is locked.
1638600
The Snapshot copy does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
