Delete a volume snapshot
Deletes a volume snapshot to remove an unwanted or outdated snapshot from your storage system.
HTTP method and endpoint
DELETE /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
snapshot delete
Learn more
volume.uuid |
string |
path |
True |
Volume UUID |
uuid |
string |
path |
True |
Snapshot UUID |
ignore_owners |
boolean |
query |
False |
If true, ignore snapshot owners when deleting.
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Code
| Error Code | Description |
2 |
An invalid value was entered for one of the fields. |
524481 |
Snapshot was not deleted because the associated volume is locked or fenced. |
1638521 |
Snapshots can only be deleted on read/write (RW) volumes. |
1638538 |
Cannot determine the status of the snapshot delete operation for the specified volume. |
1638543 |
Failed to delete snapshot because it has an owner. |
1638555 |
The specified snapshot has not expired or is locked. |
1638600 |
The snapshot does not exist. |
1638644 |
POST, DELETE, and PATCH requests on the snapshot session endpoint are not supported on this platform. |
1638652 |
The ignore-owners option cannot be used with POST and PATCH operations. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
