Delete a volume snapshot
DELETE /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced In: 9.6
Deletes a Volume snapshot.
Related ONTAP commands
snapshot delete
Learn more
volume.uuid  |
string  |
path  |
True  |
Volume UUID  |
uuid  |
string  |
path  |
True  |
Snapshot UUID  |
return_timeout  |
integer  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
job  |
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Code
| Error Code | Description |
2  |
An invalid value was entered for one of the fields.  |
524481  |
Snapshot was not deleted because the associated volume is locked or fenced.  |
1638521  |
Snapshots can only be deleted on read/write (RW) volumes.  |
1638538  |
Cannot determine the status of the snapshot delete operation for the specified volume.  |
1638543  |
Failed to delete snapshot because it has an owner.  |
1638555  |
The specified snapshot has not expired or is locked.  |
1638600  |
The snapshot does not exist.  |
1638644  |
POST, DELETE, and PATCH requests on the snapshot session endpoint are not supported on this platform.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
