REST API reference
Delete a volume snapshot
Deletes a volume snapshot to remove unnecessary or outdated snapshots from your storage system.
HTTP method and endpoint
DELETE /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
  • snapshot delete
volume.uuid
string
path
True
Volume UUID
uuid
string
path
True
Snapshot UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Code
Error Code Description
2
An invalid value was entered for one of the fields.
524481
Snapshot was not deleted because the associated volume is locked or fenced.
1638521
Snapshots can only be deleted on read/write (RW) volumes.
1638538
Cannot determine the status of the snapshot delete operation for the specified volume.
1638543
Failed to delete snapshot because it has an owner.
1638555
The specified snapshot has not expired or is locked.
1638600
The snapshot does not exist.
1638644
POST, DELETE, and PATCH requests on the snapshot session endpoint are not supported on this platform.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
